New Member
jeffl
Message 1 of 6 (7,845 Views)
Custom subassembly import error
7845 Views, 5 Replies
08-08-2013 10:51 AM
I am having trouble using imported custom subassemblies.  I get the following message in the event view when i try to attach a subassmbly to an assembly:
[Something wrong with current subassembly: Failed to create a 'Settings' from the text 'Assembly references and imported namespaces serialized as XML namespaces'.]  (Source: Subassembly.CC_Guardrail_Type_31
I am using Civil 3d 2013 version on a windows xp 32 bit machine.
Active Member
tore.lindell
Message 2 of 6 (7,810 Views)
Re: Custom subassembly import error
08-08-2013 11:38 PM in reply to: jeffl
Hi
This happens after installing Servicepack 2.
I have submitted a Support Request.
Member
genepaulacepeter
Message 3 of 6 (7,786 Views)
08-09-2013 10:58 AM in reply to: jeffl
People who use Subassembly Composer 2013-2014, don't install 2013 SP2 and 2014 hotfix 1 because you will get
an import error message.
troma
Message 4 of 6 (7,741 Views)
08-13-2013 05:59 AM in reply to: genepaulacepeter
Same problem here?
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/C3D-2014-Hotfix-1-problem/m-p/4323064#M208166
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Member
tore.lindell
Message 5 of 6 (7,708 Views)
08-14-2013 11:37 PM in reply to: jeffl
Distinguished Contributor
ceethreedee.com
Message 6 of 6 (7,681 Views)
08-15-2013 01:54 PM in reply to: tore.lindell
Yep Install DOT NET 4.5. Subassemblies now work.
Civil 3D 2014 (SP2)
Win 7 Pro x64 -DELL Precision Workstation T3500
Intel Xeon 3.3GHz (w3680) -24Gb Ram
NVIDIA Quadro 2000 (1GB)
ceethreedee.com
