Civil 3D Forum
Custom subassembly import error
5 REPLIES 5
9062 Views, 5 Replies
I am having trouble using imported custom subassemblies.  I get the following message in the event view when i try to attach a subassmbly to an assembly:
[Something wrong with current subassembly: Failed to create a 'Settings' from the text 'Assembly references and imported namespaces serialized as XML namespaces'.]  (Source: Subassembly.CC_Guardrail_Type_31
I am using Civil 3d 2013 version on a windows xp 32 bit machine.
5 REPLIES 5
Hi
This happens after installing Servicepack 2.
I have submitted a Support Request.
People who use Subassembly Composer 2013-2014, don't install 2013 SP2 and 2014 hotfix 1 because you will get
an import error message.
troma
ceethreedee.com
Yep Install DOT NET 4.5. Subassemblies now work.
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
Rail Community
