Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Custom subassembly import error
5 REPLIES 5
9051 Views, 5 Replies
I am having trouble using imported custom subassemblies.  I get the following message in the event view when i try to attach a subassmbly to an assembly:
[Something wrong with current subassembly: Failed to create a 'Settings' from the text 'Assembly references and imported namespaces serialized as XML namespaces'.]  (Source: Subassembly.CC_Guardrail_Type_31
I am using Civil 3d 2013 version on a windows xp 32 bit machine.
5 REPLIES 5
Hi
This happens after installing Servicepack 2.
I have submitted a Support Request.
genepaulacepeter
People who use Subassembly Composer 2013-2014, don't install 2013 SP2 and 2014 hotfix 1 because you will get
an import error message.
troma
in reply to: genepaulacepeter
ceethreedee.com
Yep Install DOT NET 4.5. Subassemblies now work.
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
Rail Community
Ā
Ā
