John Mayo
Solved by andrewpuller3811. Go to Solution.
Solved by jmayo-EE. Go to Solution.
Dont know the first thing about it but does this get you any closer?
http://blogs.rand.com/civil/2011/03/customize-your-civil-3d-reports.html
Joe Bouza
Have a look att he attached report.
The pipe table headings start around line 81.
I have commented out the the choice for 3d pipes forcing 2d pipes headings on line 118 and the heading for edge to edge on line 124.
The pipe table data starts around line 155
I have commented out the choice for 3d pipes forcing 2d pipes lengths on line 271 resulting in values for 2d lengths only and I have commented out the edge to edge value on line 278.
I used MS Web developer Express 2010 to open the file which allows you to comment out lines or large blocks and also provides basic error checking.
From what I can tell, the xsl files are a mix of html and xsl programming, which allows choices, calculations etc, to be made based on data values in the xml files.
John Mayo
John Mayo
John,
Sorry for the delay, I have been busy and this thread got pushed down the forum a long way.
Yes it is possible.
The attached file has a new column added to the structures table called Description and the values are filled in that column.
First off, there needed to be an extra column added to the table which is done on line 302. Pretty easy that part.
Second, a variable need to be created to hold the value of the description. This was done on line 372 with creation of the variable "Description" and then assigning it the value of desc.
The desc value is picked up from the XML output from civil 3d. If you want to add other values that are not in a report, have a look in an exported Land XML file and any of the attributes in the XML file can be fed into the report and added to the table. For example the Structures have attributes - name, desc, elevRim, elevSump plus other attibutes that are processed to get sump depth etc.
Third and last, the variable created above needs to be used to insert its value into the table. This is done with lines 396 to 398.
Hope this helps.
