Civil 3D Forum
Curve tag label wont display in table
1 REPLY 1
civman_daar
199 Views, 1 Reply
I have an alignment that is line and curve tagged for a table.  The last segment of the alignment is a 3 point curve.  It shows up in the alignment grid view, and is tagged.  When the table is produced the everthing comes in except the 3 point curve I mentioned. Any ideas?
1 REPLY 1
IanMcClain
in reply to: civman_daar
Try the Add Items tool from the ribbon when you select the table, use the select from Pick On-Screen button in the bottom left to select the reluctant label. That should add it to your existing table.
Ian McClain
Rail Community
