We are using Civil 3D 2014.
We have an alignment curve table and the data text, first data entry (curve number) is appearing as color by layer (magenta), when all colors are set as explicit colors by element in table style under Display tab. How do I control the color of the first entry to be color by element instead of by layer?
Can you post a drawing? I can't get this behaviour. No matter what I try it works correclty.
Yes, attached is an image of the table. Shows data as color yellow, due to display being set to yellow color (not by layer). Then I changed the layer color to magenta and noticed that the first data entry (curve number) changed with the layer color, as if, it is set to color by layer, which it is not. It appears that this is a small bug? My work-around is to just change the layer color to yellow and all appears as should. I am curious to learn if there is a separate control for the first data entry color control?
