Civil 3D Forum
Curve+Curve+Spiral
2 REPLIES 2
Umit.Arslan
508 Views, 2 Replies
Curve+Curve+Spiral
Hi
How can i add a "curve+curve+spiral" to the PI point "S1"?
- Umit Arslan -
Survey Engineer
Civil 3D 2018 x64
Windows 8.1 Pro 64-bit
32GB RAM
2 REPLIES 2
I would break up the alignment so I could use adding curves from end of entity (starting at S1) and go from there. Others might have better suggestions.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
sboon
in reply to: ericcollins6932
Start by breaking apart the PI, then you can add the pieces you need to connect the tangents.  It depends on what parts of the curve-curve-spiral are constrained and which are not.  I've attached a drawing with several possible combinations.
  • The first alignment has a floating curve with a specified radius attached to the incoming tangent, a second floating curve attached to that and a free spiral connecting to the outgoing tangent.
  • The second alignment has a floating curve-spiral with specified radius and spiral length attached to the outgoing tangent and then a free curve between that and the incoming tangent.
  • The third alignment has a curve with fixed centerpoint and radius in the middle, then a free curve connecting from the incoming tangent to it, and a free spiral connecting to the outgoing tangent.
There are probably more possibilities - choose the elements that work for your situation.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Rail Community
