Related to Civil 3D 2013. I'm trying to use the curve calculator to obtain values of a curve. The problem is the value for Degree of Curvature is 00d00'00" everytime. Is this broken in 2013 or is there some ambient setting I need to set? I've attached a screen shot.
Many Thanks,
I get the same result with the curve calculator and I do not have the service pack installed.
I tried this on my 2011 version with all service packs installed and the curve calculator worked normally.
Ditto,
2013 SP1 and "0" for degree of curve here.
Jeff,
Can you post your test drawing to make sure it's not a drawing thing. I did try with my template AND the NCS standard though.
The mystery continues!
I'm running version 2012 with the service pack installed and it works fine when I click on an arc. Not the OP's arc but one I drew.
dsigman, thanks for the input. It seems to be limited to 2013 and something to do with a bug in the unit arc length.
I have the same issue in 2011, with the service packs installed. To make it work, change the "Fixed .." from Delta to Radius. Then input the info you want and see if it doesn't work. Aggravating, but it works.
Surveyor Lee
Hi Jeff,
Could you please elaborate a bit more how to get the dialogue box that you are showing in the screenshot (curve calculator)?
Jamal
From the "home" tab, under the "draw" panel last on on the list.
See Image.
Many thanks Bruce. I got it
Best
Jamal
Is it possible to modify the units precision for the Curve Calculator? Changing the settings under"Units" has no effect nor does changing the settings in the Survey Database.
DD
