Member
0 Kudos
Post 1 of 19
Curve Calculator - Degree of Curvature
1027 Views, 18 Replies
01-06-2013 10:42 AM
Related to Civil 3D 2013.  I'm trying to use the curve calculator to obtain values of a curve.  The problem is the value for Degree of Curvature is 00d00'00" everytime.  Is this broken in 2013 or is there some ambient setting I need to set? I've attached a screen shot.
Many Thanks,
919 Kudos
Post 2 of 19
Re: Curve Calculator - Degree of Curvature
01-06-2013 11:14 AM in reply to: krismcdonald23
Have you installed the Service Pack? I have, and it appears to work correctly for me. Although the readme does not say this was an item that was corrected.
*Pro
49 Kudos
Post 3 of 19
01-07-2013 05:33 AM in reply to: krismcdonald23
I get the same result with the curve calculator and I do not have the service pack installed.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
*Pro
49 Kudos
Post 4 of 19
01-07-2013 05:35 AM in reply to: dgordon
I tried this on my 2011 version with all service packs installed and the curve calculator worked normally.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Member
0 Kudos
Post 5 of 19
01-07-2013 06:49 AM in reply to: krismcdonald23
I have SP 1 installed but still get 0 for Degree of Curvature.
41 Kudos
Post 6 of 19
01-07-2013 08:02 AM in reply to: krismcdonald23
Ditto,
2013 SP1 and "0" for degree of curve here.
Jeff,
Can you post your test drawing to make sure it's not a drawing thing. I did try with my template AND the NCS standard though.
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
Infrastructure Design Suite 2014 (SP2)
Testing Civil 3D 2015
Win 7 Pro, 64-bit
919 Kudos
Post 7 of 19
01-07-2013 08:25 AM in reply to: klugb
Bruce, I used the stock NCS dwt to test with.
919 Kudos
Post 8 of 19
01-07-2013 08:29 AM in reply to: klugb
Here's a setting to check, since I just noticed the OP's unit arc length is 0
41 Kudos
Post 9 of 19
01-07-2013 08:35 AM in reply to: Jeff_M
The mystery continues!
Bruce Klug
Win 7 Pro, 64-bit
919 Kudos
Post 10 of 19
01-07-2013 08:45 AM in reply to: klugb
OK, so looks like there is a bug when selecting the curve. If you input the values to calc a curve, without first selecting a curve, the DoC works correctly. As soon as you select an arc in the drawing, the unit arc length gets set to 0.
