Civil 3D Forum
Curb Grading
20 REPLIES 20
Message 1 of 21
1979 Views, 20 Replies
Curb Grading
I am trying to create a curb using the Grade to Distance procedure from a feature line that represents my asphalt limits.
I would grade to distance 2' with 0% grade, then .01' with 5000% grade, then 0.5' with 0% grade to finish the curb.
However when I try and go this way the corners of the curb turn out to be curves (See attached image). Is there a setting I can change to make it stop doing this? I know I could use stepped offset but I want the curb and the grading from the top back of curb to extisting ground to all be dependent of my original asphalt limits feature line.
20 REPLIES 20
Message 21 of 21
TerryDotson
in reply to: Neilw_05
Even with a less than optimal API, a lot can still be done in Civil3D.
Demo Example: http://www.dotsoft.com/demos/gmFeaLnkOfs.htm
Rail Community
