I am trying to create a curb using the Grade to Distance procedure from a feature line that represents my asphalt limits.
I would grade to distance 2' with 0% grade, then .01' with 5000% grade, then 0.5' with 0% grade to finish the curb.
However when I try and go this way the corners of the curb turn out to be curves (See attached image). Is there a setting I can change to make it stop doing this? I know I could use stepped offset but I want the curb and the grading from the top back of curb to extisting ground to all be dependent of my original asphalt limits feature line.
Sadly, with grading elements you will always get that curve in the corner.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
I guess that is not a huge deal. Does the process I amtrying to do make sense to try and use?
If you use alignments for your curb lines (offset alignment for tc and sw) and design your grading using a general plane (or more). Surface profiles and auto FL will alway be dynamic to changes in your grading.
Its a work flow; maybe not for everyone or application, but for parking lot and site grading its the bomb
Joe Bouza
Joe Bouza
Basically,I take Eric Chappels technique 1 step further by making the FL from surface profiles, that way when the dedsign plane is edited the site takes car of it self
Joe Bouza
Using offset alignments makes editing the tc and sidewalks an non-issue - they all move together, and a judiscous use of widenings handles transitions well. Ped-ramps; I grade a seperate surfaces and paste into the FG. For me, alignments add much more versitility
As I said, the number of alignments can become very numerous even for a simple site when you consider all the transitions that typically occur. You have to sample the surfaces for each of those alignments. Then you have to create featurelines from each of those alignments. You have to create numerous draping surfaces depending on the complexity of a site. So a simple site having 50 alignments requires at least 150 steps. Compared to using gradings that is a huge difference in workflows. That doesn't even acount for having to manage all the naming conventions and digging through long lists to find what you want.
All of that would be unnecessary if a single enhancemnet were added to the grading tools.
As you know, I am usiing Power Civil.
I don't quite get your hangup with the number of alignments to keep track of - you have the same number of polylines to keep track of. There is nothing to manage - they are simply used as your geometry.
I'm curious Neil, by your own words you don't use civil3d because of the inability of gradings to mitre a corner. What is the panacea you currently use for a dynamic site grading model and why doesn't it have a vast market share of the industry?
I respectfully disagree with how you envision the the steps required in the workflow described. Note this is a FL grading WF.
Where are the 150 steps? Granted I have a slanted point of view but the righ column appears to have less work
Joe Bouza
You are comparing the workflow using featurelines or polylines. I don't consider that an acceptable workflow at all. I am comparing the workflows with Gradings. If it weren't for the deficiencies in gradings we would have a much simpler workflow.
Power Civil provides dynamic modeling with many superior tools vs. C3D as far as grading goes. As to why it doesn't have greater market share, I can only speculate that alot of it has to do with their marketing strategy along with their lack of resources to develop their products in a timely manner. Part of that is due to their policy of maintaining interoperabilty, something Autodesk has little concern for. They are quite shrewd in their changing the DWG format every 3 years and their new subscription policy that essentially forces users to subscribe.
I am not implying that Power Civil is a better solution for everyone but I find it is much easier for building and editing site models vs. C3D.
Joe Bouza
Here is a screen recording showing how to apply different curb and sidewalks to a graphic element in Power Civil. The element represents edge of pavement. It has already been draped by centroid on a terrain to get it's elevation.
As the video progresses I am applying various curb and sidewalk combinations that I have defined and saved in a library to the edge of pavement. As you can see it is quite easy to change out the combinations. The software has no problem with the mitered corners.
In case you wonder, the curbs are dynamic to changes to the edge of pavement, both horizontally and vertically.
http://screencast.com/t/zlJvsTAOV9ga
Looks good!
Joe Bouza
