I've just set up a corridor. It's got five regions. I needed a few tapers so I used polylines to set targets. Here's the thing: The LinkOffsetAndWidth is following the target that I set, but the curb which should be attached to the Link is ignoring the target. i.e. the curb appears to be becoming detached from the link that it is set up with in the assembly.
Here's a screenshot. The red lines are my targets, the white is the corridor. I circled in blue the problem areas.
Mark Green
Working on Civil 3D in Canada
Solved by mathewkol. Go to Solution.
Not sure unless there is a problem with that polyline perhaps, but you realize, you are going to want to use an Offset Assembly, to get correct perpendicular Corridor projections for your curb and gutter system relative to the horizontally transitioning Target alignment.
You assume that I realize things that I may not realize. I think you use corridors much more than I do. I've read a few comments about things being or not being perpendicular, but it all flew over my head a little. Do you care to elaborate? How and why does one go about using an Offset Assembly?
Mark Green
If you don't have a profile to use with the offset I think you could also try to add more sections or increase the sampling frequency in these areas.
John Mayo
I found the problem in the south-east. My target wasn't long enough. (You can see in the original picture that nothing was following it past a certain point.) But the other problems remain.
I increased my frequency to 1.0m on tangents and 0.1m on curves. Nothing changed with the curb.
Mark Green
I can only surmise that the curb is not actually attached to the link. Look in your assembly properties, construction tab and see that everything is in there attached nicely.
Also, if you adjust the width of the link in the assembly layout, does the curb follow it?
No, they're not attached. I was just going to post that, I noticed before I read your reply. If I edit the lane to be 2m instead of 3m, the curb stays where it is:
So what do I do to fix that?
I don't follow your instructions about attching them back. Thanks.
Mark Green
I had to click "Move to" first, which appeared to move it to somewhere in the middle of nowhere. Then I had to click on "Clear Offset in Assembly" becasue I guess there was an offset set from baseline that held it in place. Once this was cleared, the curb was actually attached and moved with the link when made wider and narrower.
Thanks!
Mark Green
Unfortunately, no amount of sampling frequency addresses the corridor perpendicularity projection problem for transitioning corridor systems.
