Civil 3D Forum
Curb and Gutter Assembly Transitions
3 REPLIES 3
ryanbanning2585
1267 Views, 3 Replies
Does anyone know if there is a way to transition from an assembly with curb and gutter to one without? The tin lines on my surface and the featurelines in the corredor end up crossing each other since they connect the outside boulevard of an urban sidewalk to the edge of traveled way.
3 REPLIES 3
This is one of those instances where a picture would be worth a thousand words. Can you provide maybe a plan view of exactly what you're trying to do? I think I have the scenario right in my head, but I would love to see exactly what you're trying to connect up.
Jason Hickey
Premium Services Specialist
Thanks for the response. Here is a doc with some screen captures and explanations of what you are seeing. I am also having problems trying to transition from infall curb to outfall curb and vice versa since there is no subassembly to do this.
Thanks again,
Ryan
I'd use a conditional assembly. Switch from curbs to no-curbs at the tracks, then back to curbs after the tracks. You will need profiles to bring the sloped assembly up to flat at the tracks, and back to sloped again afterwards.
Rail Community
