Hi.
How can i have cumulative area at station on tables?
Can i have it with an expression?
I'm assuming you want a cumulative area along a corridor. You can generate these using Sample Lines & Sections. I use the Materials List, which is defined for each project, then the Calculate Materials function. I can then create a table that includes cumulative quantities, you might have to add that data as a column to include in the table.
Hi.
I want area values (daylight cut and daylight fill). On component editor it only shows [Cut Area at Station] or [Fill Area at Station] and cant use an expression that give me total cut and fill area.
[Cut Area at Station] or [Fill Area at Station] represent "End Areas" of the assembly @ a given station .
Are you looking to come up with cunmulative totals for these Cut and Fill "End Areas"?
Or are you after Square Area cumulative totals for Cut and Fill areas in "Plan View" along the surface?
HI.
All i want is to know total areas in plan view. By default civil give to me area at station...(profile view) but i want is Cut and Fill total area in plan. I dont see one expression to know those values. Its important because Fill and Cut (daylight) are in diferent costs.
Hi. Thank you Lisa Pohlmeyer .
I know those tables. That it is not what i want.
I want to give total cut and fill area in plan (daylight zones) and not relative values.
Those values that you say are relative to section area at station.
I dont want materials.
Paul:
Look at the table again. There are fill and cut areas shown between each station. I am thinking that Lisa is having the same problem as I am. Are you wanting Total Fill or Total Cut that pertains to this one sheet that you are looking at? If so, just add up the yardage between the stations on the sheet. OR please explain.
Bil
Hi.
Ok. That is correct. Area Fill and Area Cut are ok!!! Only if we want area value at station (section area) and not total slope area in plan. I know that i could use this value and multiply with some value (for example Fill area x 25 meters)...but that is not correct. I want a way (if possible) to determine total area in plan (fill and cut) because they are important. One daylight slope dont has the same dimension between stations. I hope i am explain it correct. Thank you.
Paul:
I am beginning to think that we are worlds apart. I do believe that your "area" and my "area" are referring to two different things. Perhaps a picture or three would be of some help.
Bill
Bill:
You could be correct...lol
This is area value that i want to know (daylight slope on plan view)
Area that are in table is section area at station:
I dont want this area. I want total area in plan (Cut ou Fill).
Thank you.
Paul:
I believe we are making progress. Are you trying to get the area of the existing ground that would be disturbed by construction? Area would be bounded by the toe of slope around the entire project (either cut or fill).
2D or 3D area?
Bill
If you draw that polyline around the entire perimeter along the daylight line the polyline will give you the area.
Bill
Hi Bill,
This makes no sense. If i have 30 km road, i have to do it manually? I do not think that is the best way.
If you have a single surface for the corridor, open up the statistics window and the 2D area should be available.
Bill
Bill,
Thank you.
I have that corridor surface, but again...it has only 2D and 3D total area surface and not daylight slope area (cut or fill) projected on terrain surface.
Perhaps if you would ever spell out what you are trying to do, someone could help. Are you trying to get the ground area for seeding?
Bill
