Civil 3D Forum
CUI Land invalid
1 REPLY 1
164 Views, 1 Reply
CUI Land invalid
Single Seat User LDT 2006 Civil3d Companion, Winxp Pro 1.25gb ram 7.76gb
hard disk available. I have recently started using the Civil3d portion of
the program. Starting a new dwg in Civil3d, I either import data from Land
desktop or import Land Xml data. Aftre working in Civil3d I have been saving
the result dwg in 2004 format to a folder of my creation on C drive.I have
done this experimenting with at least 10 drawings with data derived from my
existing Land Projects 2006 and some outside LandXml files. Today when I
started-up LDT to my suprise there were no workspaces or menues available. I
executed to menuload command and sucessfully loaded the following .cui :
acad sample workspaces, civil, dbcon, acad, and Trimble. When I try to load
the Land .cui I get an error message "this file is invalid". I have varified
the support path of all .cui in both LDT and Civil3d which all seem to be in
order. I have executed the "Reinstall or Repair Autodesk Landesktop 2006"
option in Windows Add Or Remove Programs to no avail. Any ideas?
E C. surveyor
1 REPLY 1
clarkee006 said the following on 5/7/2006 6:20 PM:
Actually, it's "Civil3D", "Land Desktop", and "Civil Design Companion"
A Repair/Reinstall will fix this. If all else fails, copy the untouched
version of this file from the \UserDataCache directory under your LDT
directory.
Here are the stats on the untouched file:
Directory of C:\Program Files\Autodesk Land Desktop
2006\UserDataCache\Support
09/28/2005 05:05 PM 910,479 Land.cui
1 File(s) 910,479 bytes
0 Dir(s) 56,169,279,488 bytes free
R.K. McSwain
http://rkmcswain.blogspot.com
Rail Community
