Member
SSicina
Message 1 of 5 (257 Views)
Crossing Tin Lines
257 Views, 4 Replies
12-03-2013 12:55 PM
I have built a alingment, corridor, and surface of a driveway but I have a few holes in my surface.  I tried to add lines to my TIN surface and some filled in properly but others would not and I had TIN lines that crossed (actually they are 4 different lines that meet at on point).  Why does this happen and how can I fix it?
Alfred.NESWADBA
Message 2 of 5 (245 Views)
Re: Crossing Tin Lines
12-03-2013 01:49 PM in reply to: SSicina
welcome @forums.autodesk.com !
What version of Civil3D do you have and do you have installed the latest servicepack?
What happens if you export the surface to LandXML and reimport it into a new drawing?
- alfred -
Alfred NESWADBA
neilyj
Message 3 of 5 (235 Views)
12-03-2013 02:08 PM in reply to: SSicina
TIN lines cannot cross each other - fundamental principle of triangulation.
try drawing a polyline around the gap areas and add to surface as a show boundary
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
mathewk
Message 4 of 5 (221 Views)
12-03-2013 03:39 PM in reply to: SSicina
Tough to say why this happens without your drawing we have no idea how the surface was created. Those "crossing" TIN lines usually happen when you add lines in an area where there are break lines defined.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Member
SSicina
Message 5 of 5 (195 Views)
12-04-2013 06:54 AM in reply to: SSicina
We figured out the issue I had not set a corridor border and I had deleted a line that was used within the surface when I was cleaning up the extra daylighting lines.  I ressolved the issue by using a corridor border. Thanks for the help though
