Civil 3D Forum
Crossing Tin Lines
4 REPLIES 4
SSicina
558 Views, 4 Replies
Crossing Tin Lines
I have built a alingment, corridor, and surface of a driveway but I have a few holes in my surface.  I tried to add lines to my TIN surface and some filled in properly but others would not and I had TIN lines that crossed (actually they are 4 different lines that meet at on point).  Why does this happen and how can I fix it?
4 REPLIES 4
Alfred.NESWADBA
in reply to: SSicina
welcome @forums.autodesk.com !
What version of Civil3D do you have and do you have installed the latest servicepack?
What happens if you export the surface to LandXML and reimport it into a new drawing?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
neilyj666
TIN lines cannot cross each other - fundamental principle of triangulation.
try drawing a polyline around the gap areas and add to surface as a show boundary
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
mathewkol
Tough to say why this happens without your drawing we have no idea how the surface was created. Those "crossing" TIN lines usually happen when you add lines in an area where there are break lines defined.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
SSicina
We figured out the issue I had not set a corridor border and I had deleted a line that was used within the surface when I was cleaning up the extra daylighting lines.  I ressolved the issue by using a corridor border. Thanks for the help though
Rail Community
