Civil 3D Forum
Crossing Daylight Lines
3 REPLIES 3
C3DUser
779 Views, 3 Replies
I've created a corridor with a Cul-de-sac. The problem is that the daylight lines targeted to the existing ground intersect at turn segments:
Daylight lines intersected
which results in defects of corridor surface:
I wonder if there's a way to overcome this.
3 REPLIES 3
C3DUser
in reply to: C3DUser
The drawing is here.
peterfunkautodesk
In cases like this where the radius is very tight I would not daylight in those areas but instead use grading. You can grade from a feature line and have it stay in sync with corridor changes.
Peter Funk
Peter Funk
C3DUser
Thank you.
Rail Community
