Hey all,
I have a bit of a peculiar issue with Civil 3D 2012. I created several cross sections for a roadway design utilizing sample lines. I created multiple sample lines along the CL alignment and inserted the cross sections without any errors. The peculiar part is when I try to inquiry or label any cross section, nothing happens. Using the inquiry tool, I get an message that reads "Warning: Specified point is outside the section view. Try Again." If you see the attached PDF, you'll notice that the point I selected is dead center of the particular cross section in question. When I attempt to use labels to mark elevations, in the command line, it repeats "Pick a Point" but does not insert a label.
Anybody have any suggestions as to why this might be? I created other cross sections in the same fashion and do not have this issue.
Hey Jeff_M. Thank you for your response! Although it doesn't show world coordinates in the attachment, the problem arose prior to that changing. Unfortunately, the UCS doesn't help in this situation.
