Does anybody have a good style to label cross sections at profile grade, top of curb, bottom of curb, grade breaks, and back of walks? Do I set a point or something in my assembly to use to label those points?
You can use your code set styles to label the top of curb, bottom of curb and back of walks.
Depending on your assemblies, you can probably also label you profile grade and grade breaks.
You need to edit your code set style you use and set a label style for the Point codes you want to label.
