Distinguished Contributor
SurveyorLee
Message 11 of 14 (162 Views)
Re: Cross sections & Reports
10-21-2012 01:29 PM in reply to: novais
YOu say the contractor doesn't need it.  How do you know? Have you asked what the intended use will be. Around here, most of the contractors have their own survey crews.  Give them the NE, and they can go.  MOst have not worked with station and offset enougth to do it if the road is anything but straight.
Surveyor Lee
Active Contributor
novais
Message 12 of 14 (158 Views)
10-21-2012 02:05 PM in reply to: SurveyorLee
From my experience working with survey teams and contractors, they work mostly with lists providing station,X, Y and Z elements.
The cross sections never shows X,Y info.
Even so, this is getting out of my question scope.
Thanks for the toughts sharing!
LisaPohlmeyer
Message 13 of 14 (120 Views)
10-25-2012 11:51 AM in reply to: novais
Would this work for you?  This is a section view label with an Reference Alignment label component.  Yes, you'd have to add them manually, but may be easier than copy/paste.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
Active Contributor
novais
Message 14 of 14 (109 Views)
10-26-2012 01:49 AM in reply to: SurveyorLee
Thanks Lisa for the idea, it's another aproach to the question.
Meanwhile i've issued my first cross sections to the contractor for aproval...
I've created a feature line report with my top surface and for each station i copy from excel and paste it into c3d.
Thanks! :smileyhappy:
