Member
0 Kudos
Post 1 of 7
Cross section with Sample lines problem
315 Views, 6 Replies
01-13-2013 07:40 PM
I have my surface, aligment and sample lines created, but I cant get my sample lines profiles.
The grid apperas without data, it is like I have never selected a surface, but I did !
This is what I get , totally empty
288 Kudos
Post 2 of 7
Re: Cross section with Sample lines problem
01-13-2013 09:00 PM in reply to: sakuramukuro
Layer froznn? Style messed up? Go to the section view properties and Section tab. Does it show a section with appropriate values?
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
169 Kudos
Post 3 of 7
01-14-2013 06:22 AM in reply to: sakuramukuro
This is probably due to not sampling the correct surfaces.  If you click on one the the sample lines, in the contextual ribbon, select Sample More Sources.  If your surfaces are in the left pane, add them to the right pane.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
71 Kudos
Post 4 of 7
01-14-2013 06:55 AM in reply to: sakuramukuro
Is the surface set to display?  The sections won't display if the surface is off.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
169 Kudos
Post 5 of 7
01-14-2013 06:59 AM in reply to: LisaPohlmeyer
The surface being set to No Display has no affect on the cross sections.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
71 Kudos
Post 6 of 7
01-14-2013 11:33 AM in reply to: TRogers
Todd
I could have sworn that used to be the case, maybe in a previous version, and by habit I still keep my surfaces visible.
Lisa Pohlmeyer
418 Kudos
Post 7 of 7
01-14-2013 11:39 AM in reply to: TRogers
If the No Display style has been set to not display in Section mode then it won't show up in section views.
My template has two surface styles.  One is NoDisplay which means that the surface does not show in any mode.  The other is NoPlanDisplay which is used for surfaces that I want to see in section views, or the corridor editor etc.
