Civil 3D Forum
Cross section with Sample lines problem
6 REPLIES 6
720 Views, 6 Replies
I have my surface, aligment and sample lines created, but I cant get my sample lines profiles.
The grid apperas without data, it is like I have never selected a surface, but I did !
This is what I get , totally empty
6 REPLIES 6
mathewkol
Layer froznn? Style messed up? Go to the section view properties and Section tab. Does it show a section with appropriate values?
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
ToddRogers-WPM
This is probably due to not sampling the correct surfaces.  If you click on one the the sample lines, in the contextual ribbon, select Sample More Sources.  If your surfaces are in the left pane, add them to the right pane.
Todd Rogers
Lisa_Pohlmeyer
Is the surface set to display?  The sections won't display if the surface is off.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
The surface being set to No Display has no affect on the cross sections.
Todd Rogers
Todd
I could have sworn that used to be the case, maybe in a previous version, and by habit I still keep my surfaces visible.
Lisa Pohlmeyer
Civil 3D User
sboon
in reply to: ToddRogers-WPM
If the No Display style has been set to not display in Section mode then it won't show up in section views.
My template has two surface styles.  One is NoDisplay which means that the surface does not show in any mode.  The other is NoPlanDisplay which is used for surfaces that I want to see in section views, or the corridor editor etc.
Steve
Expert Elite Alumnus
Rail Community
