Civil 3D Forum
Cross Section View
2 REPLIES 2
1093 Views, 2 Replies
Cross Section View
I have 2 questions related to the Cross Sections View and I would like to know how to do it:
- Can be inserted in the XS View the fences for example? I did an alignment for this fence parallel to the road but I don’t know how to show it in XS
- I saw on youtube that the extension lines from the Band Design Levels to the Red Line can be shown
Attached is the cross section in this stage with highlighted comments
Thanks in advance
Lucian
2 REPLIES 2
andrewpuller3811
For question 1,
Create a profile from the existing surface along your alignement you have for the fence.
Create a marker style for your fence object.
Select a Section View, right click and select Section View Group Properties...
On the Section Views tab, click the Elipsis button under Profile Grade.
Choose the alignment for your fence from the alignment drop down and click the Add button.
Change the marker style to your newly created Fence marker style, then click Ok.
Click OK.
For question 2,
Look at creating section label style for grade brakes which is made up of one component, being a line.
The major properties of the still are -
Starting point anchor component - <Feature>
Starting point anchor point - Anchor Grade Break
Use End Point Anchor - True
End Point Anchor Component - <Feature>
End Point Anchor Point - Anchor Grade Break Extension
Then attach this label style to your red section with the anchor point being the Graph View Bottom.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
in reply to: andrewpuller3811
Thanks Andrew.
It was a really great answer. It worked perfect.
As one more question, do you know if I can replace my labels from Corridor Code set style - Point Label Style, as shown in the previous sketch as Centreline, Channel labels etc to be included in the band set?
Rail Community
