Alright, this one is pretty hairy.
I'm working on a project where I've got about 800 cross sections. I've created multiple views and linked it to a template and have the template title block all set up to auto populate the sheet number based on the sheet set manager, all's good. I've got 6 cross section on each layout. 140 sheets in my sheet set manager. The last thing that I'm needing to do to get these out to the client is populate a block attribute in the title block that says "Cross Section 4500+00.00 - 4506+00.00". On my first submittal, I did it by hand and took about 4 hrs to go thru all 140 layouts.
Heres what I want.
I want a block attribute (title block att.) to be linked to something that will auto populate the attribute with the stations that are present on that page.
eg. Page one layout is called Cross Section - 1. Layout 1 has 6 cross sections on it at 100' stationings. I want to link the title block attribute "Exhibit_Name" to something that has the stationing values for each layout so I dont have to go thru each layout and populate the attribute with "Cross Section xxxx+xx.xx - xxxx+xx.xx"
I have a feeling that I can tweak the sheet set manager to name the layouts Cross Section - ####+##.## - ####+##.## and then link the attribute in my title block the the layout name, but I dont know how to make this happen.
The skinny:
Each Layout has 6 cross sections on it. I want to auto populate either a piece of text or an attribute in my title block to display theses stations.
Ready, GO!!!
Any input will be greatly appreciated
If I'm following you correctly here, I see 2 options to get the "Layout Name" populate a field with your section stations = the Layout Name.
Option 1:
Rename all Layouts to xxx+xxx to xxx+xxx etc. as desired.
Create the Field using Field Category: Other > SystemVariable > CTAB (Which represents the "Current Tab")
Option 2:
Very similar to Option 1 where Layouts "Sheet Title" is renamed to match Layout Name in sheet set manager via the rename & renumber option.
Create the Field using Field Category: Sheet Set > CurrentSheetTitle
The option in PP is available to automatically name the tabs <startStation - EndStation>. Is it there in the section generator?
Your Name
Your Name
Hello Danloes,
I am working the same. But Im having trouble of linking my sections to templates. Will you give your procedure? Thanks!
-yonah 🙂
@yonah.ge wrote:Hello Danloes,
I hope this helps. I'm not looking at that drawing right now so some of the tab names may differ from what I specified. This is the general gist of what I went thru to make this work properly.
