I am having difficulty creating cross sections, I have my surface, profiles, alignments, corridors, sample lines, etc.
When I attempt to create the cross sections I get an error that says "FAILED OPENING FIRST SECTION LINE GROUP OF ALIGNMENT <lists alignment name>"
Please help!!!
Solved by sopendrive12. Go to Solution.
Solved by hgohel. Go to Solution.
Does an AUDIT pass on your drawing?
Examine each sample line group for the alignment - is everything OK there? If not, create (multiple) section view will give you this error.
I ran the audit and that seemed to resolve the cross section issue. Now my design corridor seems to be pinning itself to a zero elevation and most of my feature lines are spiking to zero elevations at multiple points over the featureline.
I have had the same problem and audit did not fix this problem. So, I restarted the civil 3d drawing and then it worked fine.
Cheers,
Toufiq Rahman
hi,
i have same problem >>> i have my corridor and my sample lines , but when i do multiple cross sections ,send for me same problem and same massage ...
please help me
I was pulling my hair out and took a look at the Forum.....Thank you. Audit seemed to work in my case as well.
Had this problem on the end of a workday. Next day it was still present so a full laptop restart didn't solve the problem.
A simple Audit did work though.
