Civil 3D Forum
cross section problem
10 REPLIES 10
Message 1 of 11
mherrmann
12991 Views, 10 Replies
I am having difficulty creating cross sections, I have my surface, profiles, alignments, corridors, sample lines, etc.
When I attempt to create the cross sections I get an error that says "FAILED OPENING FIRST SECTION LINE GROUP OF ALIGNMENT <lists alignment name>"
Please help!!!
10 REPLIES 10
Message 2 of 11
hgohel
in reply to: mherrmann
Does an AUDIT pass on your drawing?
Examine each sample line group for the alignment - is everything OK there?  If not, create (multiple) section view will give you this error.
Himanshu Gohel
Message 3 of 11
mherrmann
I ran the audit and that seemed to resolve the cross section issue. Now my design corridor seems to be pinning itself to a zero elevation and most of my feature lines are spiking to zero elevations at multiple points over the featureline.
Message 4 of 11
toni
Smiley HappyRunning audit worked for me also.
Message 5 of 11
sopendrive12
I have had the same problem and audit did not fix this problem. So, I restarted the civil 3d drawing and then it worked fine.
Cheers,
Toufiq Rahman
Message 6 of 11
9231989t
in reply to: sopendrive12
hi,
i have same problem  >>> i have my corridor and my sample lines , but when i do multiple cross sections ,send for me same problem  and same massage ...
please help me
Message 7 of 11
i did restart my C3D & it worked for me too...
THX.
Message 8 of 11
tingraham
I was pulling my hair out and took a look at the Forum.....Thank you. Audit seemed to work in my case as well.
Message 9 of 11
evillabon
in reply to: hgohel
TOCA METERSE AL  PROPIEDADES DE ALINEAMIENTO Y RENOMBRALO
OSEA  ALIGMENT PROPERTIES
Message 10 of 11
sertacku
Restart also worked for me..
Message 11 of 11
r_griffith
Had this problem on the end of a workday. Next day it was still present so a full laptop restart didn't solve the problem.
A simple Audit did work though.
Rail Community
