3 Kudos
Post 1 of 5
cross section label
133 Views, 4 Replies
12-20-2012 06:39 AM
created a pipe label for cross-sections.  label pipes and everything appears good.  close the dwg (save it) and reopen labels are gone. any suggestions?
C3D 2011, 2013 (latest updates)
Win 7 Pro, 64-bit
16 GB RAM
266 Kudos
Post 2 of 5
Re: cross section label
12-20-2012 06:42 AM in reply to: rwatson654
This was a known issue in 2011.  I expected it to be fixed by now, very disapointed.  My only workaround was to explode the labels.
Credit where credit is due! Give kudos or accept as solution whenever you can.
3 Kudos
Post 3 of 5
12-20-2012 06:46 AM in reply to: troma
That sux. Guess I will have to explode too.  Do you know if this is an issue in 2013?  Maybe time to switch.
Thank you for the reply.
911 Kudos
Post 4 of 5
12-20-2012 07:00 AM in reply to: rwatson654
It was a problem in the initial release of C3D2013. SP1 corrected it.
3 Kudos
Post 5 of 5
12-20-2012 07:03 AM in reply to: Jeff_M
Thank you. was just getting ready to test. hard to test when you are trying to get projects out the door.  hard to finish a project when labels dispear.
