Please help me,
While I was out, my partner somehow now has two existing ground lines in my cross-sections. ####exist and ####exist (1). They are offset by about .5 feet left to right. Where do I remove the surtface ###exst (1) from the cross sections. I am looking now.
Select your section view then go to sample more source, then you can remove surfaces or corridors
Sean..........
If you select both sections in one section view, does the wrong line display drawing object grips? If so that sample of the EG was lost, exploded or corupted in each section view and is no longer linked to the surface. This could explain the drop in grade if you have only one EG surface in the file.
John Mayo
