Hello All,
I have what I assume is a very easy to solve problem, I just can't figure out exactly how to do it.
I have a band label set up for my cross sections that will show existing grade and finish grade elevations at the 0' offset mark of each section. However, the band does not show when I create my sections. The only way I can seem to get it to show is by right clicking a section, section view properties, bands tab, click 'import band set' at bottom of window, and select they style i want to use. But I have to do this for each section individually. That is a problem as I have over 200 sections for one piece of this project.
There must be a way for this to come in by default, any help?
Thanks!
Rene
Solved by Jeff_M. Go to Solution.
