Civil 3D Forum
Cross section band question
3 REPLIES 3
neilyj666
1711 Views, 3 Replies
I've produced some cross sections but want to show the Offsets (and Levels) in the bands at say 10m intervals but can't figure out how to do it - any ideas?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
3 REPLIES 3
Ed.McGriskin
in reply to: neilyj666
I think adjusting your minor  station interval to 10m should do it. If you are showing the minor station labels that is.
Ed McGriskin, P.Eng.
Project Engineer @ HUSSON
Remember to accept the solution so others can find the solution also.
MikeEvansUK
Two ways to do this.
Edit the Section style > Horizontal axis. Minor / Major interval. Then Display Major / Minor Levels and markers in the Band for a Global display, for single display then edit the section view uncheck the match major / minor grid intervals on bands tab and change the major / minor interval values. In each case you need to change the bandstyle to show the major / minor text.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
neilyj666
in reply to: MikeEvansUK
Thanks for all the replies - it was a mainly an incorrectly set up band style causing the problem but it's sorted out now 🙂
Rail Community
