Civil 3D Forum
Critical Station
2 REPLIES 2
219 Views, 2 Replies
Critical Station
Hi everybody! Can someone tell how can I initially determine critical station value that I will use in sampling a single surface for cross section?
2 REPLIES 2
Critical stations are those that are not in your regular sampling interval (say every 25') but are of interest - such as intersections or utility crossings (say sta 1+37.65). If you do not have any 'critical' stations, don't specify any. -- Karl Fuls PLS Autocad AEC Training and Consulting Autodesk Discussion Group Facilitator Janet Manzano wrote: > Hi everybody! Can someone tell how can I initially determine critical > station value that I will use in sampling a single surface for cross > section?
Hi Janet, Several months ago I posted an Alignment Labeller Program to the Customer Files NG. This program writes all locations you label with it to the AlignmentName.SMP file. You can than sample sections from the file to get sections at all places you label with the program. The program is totally open source code and will only work on one version of Land Desktop. It's up to the user to change the library files to work in other versions. -- Laurie Comerford CADApps www.cadapps.com.au "Janet Manzano" wrote in message news:40be89cd$1_2@newsprd01... Hi everybody! Can someone tell how can I initially determine critical station value that I will use in sampling a single surface for cross section?
Rail Community
