Civil 3D Forum
Creation tools
1 REPLY 1
212 Views, 1 Reply
Creation tools
For some reason I cannot open any of my creation tools, nor can I create anything like alignments. Whats wrong? I am a relatively new user. I am using AutoCAD Civil 3D 2011.
1 REPLY 1
tcorey
Try a brand new drawing. Are you tools working there? If so, possibly you have opened a Civil 3D drawing that was created in either Civil 3D 2012 or 2013. In either case, Civil 3D commands will not be available in 2011.
If a brand new drawing does not work, possibly you opened AutoCAD using the AutoCAD Civil 3D as AutoCAD shortcut. This shortcut opens Civil 3D in emulation of vanilla AutoCAD, so the civil tools don't work.
If that's not it, check your Support File Search path to be sure your software is set-up correctly. If it's wrong, an easy fix is to run a repair installation of the software.
Best regards,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
