Civil 3D Forum
Creating TIN surface from Terramodel
2 REPLIES 2
jarrod.mills
896 Views, 2 Replies
Hi all,
Im new to Civil 3D and civil designing in general (Mechanical/Piping)
I have been asked to create a TIN surface from a Terramodel exported dwg file
The Engineer would like to use this in Navisworks as a solid (face?) surface
How do I do this? Any help will be greatly appreciated
Sorry for the noob post
Jarrod
2 REPLIES 2
neilyj666
in reply to: jarrod.mills
What have you been given in the Terramodel dwg - you will most likely have the 3D faces already which I suspect could be used in Navisworks with no further manipulation (not entirely sure as I don't use Navisworks)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
HansSMS
When exporting the DWG file in Terramodel the 3D faces must be active and the export 3d checkbox must be on otherwise there will be no heights. All the surface data will be in one layer, that's how Terramodel works.
Hans Moller
Surveying & Management Services
Gladstone Australia
Metabox 16GB, Intel i7-9700K 3.6Ghz, 500GB SSD, 2TB HDD Nvidia GTX 1060
AutoCAD Civil 3D 2018
Rail Community
