AutoCAD Civil 3D General Discussion
MKH-VB
Message 1 of 11 (456 Views)
Accepted Solution
creating thickness contours (difference between 2 surfaces)
456 Views, 10 Replies
03-01-2012 11:35 AM
I have created 2 surfaces of a matierial that is buried, using drill hole data.  I have a surface for the top, and then a surface for the bottom of this material.  I then created a 3rd suface comparing these 2, creating an isopac contour showning the thickness of the material.  My question is this:.....is there a way to make the zero (0) contour show up?  I have a .5 contour interval, but 0 doesn't generate.  Could i be missiing something in the settings?  Thanks for any help.
mkh
Surface Properties (right click in Prospector, right click when selecting surface in the drawing, or on the Ribbon), Analysis tab, under Analysis type choose User Defined Contours, for the Range set it to 1, use the arrow to the right to 'send' it to the window below, change the elevation to 0.
*Expert Elite*
Jeff_M
Message 2 of 11 (452 Views)
Re: creating thickness contours (difference between 2 surfaces)
03-01-2012 11:53 AM in reply to: MKH-VB
What version of C3D are you using?
Jeff_M, also a frequent Swamper
MKH-VB
Message 3 of 11 (449 Views)
03-01-2012 12:00 PM in reply to: Jeff_M
using 2011 C3D
mkh
*Expert Elite*
Jeff_M
Message 4 of 11 (444 Views)
03-01-2012 12:08 PM in reply to: MKH-VB
OK, well I know I recall seeing this issue, but I'm pretty sure it was for an older version....and now I can't find any references to it.
Make sure your Major contours are set to display. If they are and 0 contour still doesn't show....
Make sure your UserDefined contours are set to display. Do a Surface Analysis for User Defined Contours, add 1 range at elevation 0. You should then be able to view the 0 elevation contours.
MKH-VB
Message 5 of 11 (436 Views)
03-01-2012 12:21 PM in reply to: Jeff_M
not sure how to do the surface analysis.
mkh
*Expert Elite*
Jeff_M
Message 6 of 11 (434 Views)
03-01-2012 12:27 PM in reply to: MKH-VB
MKH-VB
Message 7 of 11 (428 Views)
03-01-2012 12:34 PM in reply to: Jeff_M
great.....a picture is worth a thousand words they say!  That helped a lot. Thanks very much.
mkh
*Expert Elite*
Jeff_M
Message 8 of 11 (423 Views)
03-01-2012 12:41 PM in reply to: MKH-VB
Glad I could help! I know you marked a post as the solution, but thought this still might apply:
If you find a response which answers your question, please be sure to accept the actual post which helped you as the solution. This will help future searchers quickly find answers to their own questions. Thanks!
MKH-VB
Message 9 of 11 (421 Views)
03-01-2012 12:42 PM in reply to: Jeff_M
you got it.
MKH
mkh
*Expert Elite*
mathewk
Message 10 of 11 (389 Views)
03-01-2012 06:07 PM in reply to: Jeff_M
...and it helps Jeff get a better rating as a poster :smileyhappy:...
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
