Im trying to create a survey data base from the points of a drawing. I have created the survey data base. Then I specify the data source type as "Points From Drawing", then I press the tap of"Select points in currente drawing" And I cannot select anything
You should be able to select 1 point at a time, but if you have a lot of points to do the best way would be to export those points from the drawing to a point file and then import that into the survey database.
