Civil 3D Forum
Creating Survey Database from Points in Drawing
4 REPLIES 4
fjperez
507 Views, 4 Replies
Im trying to create a survey data base from the points of a drawing. I have created the survey data base. Then I specify the data source type as "Points From Drawing", then I press the tap of"Select points in currente drawing" And I cannot select anything
4 REPLIES 4
in reply to: fjperez
You should be able to select 1 point at a time, but if you have a lot of points to do the best way would be to export those points from the drawing to a point file and then import that into the survey database.
fjperez
Thanks. How do you export the point to a file point? Manually (one by one)?
Jay_B
Are these drawing points Cogo Points?
If so you should be able to select them all in the drawing to add them to the survey database using these various options.
http://docs.autodesk.com/CIV3D/2013/ENU/filesCUG/empty_concept_126.htm
Also be sure to choose "open for edit" on survey database name on survey tab of toolspace first.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
in reply to: Jay_B
That's the way.
Thanks Jay.
Rail Community
