Hi fellows,
I would like to know if it is possible in Civil 3D 2015 to create a surface (or points) from a geotiff with elevation contours and points, like the one below.
Thank you all.
Solved by antoniovinci. Go to Solution.
No way, sir: the Geotiff should be a DEM, but yours is only a "flat" raster...
Well, starting from the bounding box of your Geotiff, I downloaded a 1" Dem from http://gdex.cr.usgs.gov/gdex/
Then I extracted its 5 meters contours, in UTM84_24S system: check the attachment out, containing both isolines and Dem.
Unfortunately I didn't find a bathimetry Dem of that brazilian coast: maybe someone has a link to it..?
