I am working on a project, I was given a file with the contour already mapped out. I am tasked with finding volume of a fill I had to create. I made a 3-D polyline at the elevation I want my fill to start from and going down to my final grade. How can I make surfaces with my map. I do not have any files to make the surface off of. What is the easiest way I can make a layer, TIN has already been done but no surfaces are in the file.
Solved by tcorey. Go to Solution.
This will show you how to create a surface from existing polylines that represent contours:
