Employee
peterfunkautodesk
Message 11 of 13 (821 Views)
Re: Creating surface with polylines
11-19-2012 10:56 AM in reply to: sdhauban
Changing the units isn't going to change the elements. You need to scale the objects in the drawing by a factor of 1/12 (0.083333333). You can do this either before or after you make the surface.
Cheers,
Peter Funk
Peter Funk
tcorey
Message 12 of 13 (813 Views)
11-19-2012 12:30 PM in reply to: peterfunkautodesk
Except that I think he said the objects are incorrect in their elevations only. Scaling will mess up the x and y.
If that's the case, here's a lisp routine that will change only the elevations of your objects. This will select all LWpolylines not on frozen layers, so freeze all layers except the layers that contain your contours/polylines.
Use Appload to load the routine. It will run automatically upon load.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Member
sdhauban
Message 13 of 13 (771 Views)
11-27-2012 11:07 AM in reply to: tcorey
tcorey that worked!
Thank you guys so much!
