I recieved an .sdf file from a surveyor (Autodesk Spatial Data File) does anyone know if there is a way to create a surface in Civil 3d from this. i also revieved a file with just the trianglation for the surface in it (DTM).
For the SDF, have a look at the following:
http://www.cadtutor.net/forum/archive/index.php/t-28339.html
If you have the triangles, then you could import them as breaklines.
Don Ireland
Engineering Design Technician
