Is anyone having a problem in 2012 adding pipe networks to a profile view while creating the profile view? Every time I select the pipes I want to display and hit enter the program errors out. I am able to add the network in a separate step once the profile view has been created.
Solved by machadt. Go to Solution.
HI Scott,
No, I don't see that issue. Are any other of your files doint the same?
Yes I see it two other projects that I tested, as well as a new drawing created to test it.
I have also attached the error message that I get.
Hi Scott,
Do you have SP1 for Civil 3D 2012 installed?... if not please download and install it.
Yes I do have the service pack installed.
Side note, we were also able to replicate the error in the ACAD example drawings ruling out a project specific error.
Hi Scott,
The workaround for that will be selecting the network from the dialog box, not from the drawing, or to drawing the profile first and add the specific pipe network as Draw Parts in Profile View.
Thank you, I am aware of the work around. I was mostly interested in reporting this as a defect.
