Civil 3D Forum
Creating Pressure Pipe Content Problem - Please help
9 REPLIES 9
Message 1 of 10
453 Views, 9 Replies
I’m using civil 3D 2015, and when I try to create pressure pipe content I run into problems.
Let me explain how I have been going about it.
  1. I created a 3D solid of the filling (in this case and Isolating Valve)
  2. I drew a line from the centre valve connection point on one side to the centre valve connection point on the other side.
  3. I inserted the connection point to the end point of the drawn line and indicated the direction.
  4. I did this again for the other end.
  5. I then typed in “publishpartcontent”
  6. I picked the solid, then the line.
  7. Selected “mm”
  8. Selected “valve”
  9. I received the following error
Command: PUBLISHPARTCONTENT
Select a solid for publishing
Select a centerline ENTITY that represents the previously selected solid.
Specify the Measuring Unit [Inches/Millimeters] <Inches>: M
Specify the Part Type [Cap/COupling/CRoss/Elbow/Hydrant/Plug/PUmp/Reducer/Tee/Valve/Wye] <Elbow>: V
_VSCURRENT _G _zoom e _pngout C:\Users\Rob\AppData\Local\Temp\cb446570-83ad-4573-8fb3-c437ebe330aa\tempfile.png _ALL
Error during Publish: eWasErased
Please, where am I going wrong or what am I doing wrong?
All your help is much appreciated
Rob
9 REPLIES 9
Message 2 of 10
jmayo-EE
I'm not sure but I think the issue has to do with this,
Does the line extend past or fall shor of the solid's outer faces? Does the solid have a centerline you can select?
John Mayo
Message 3 of 10
jmayo-EE
Does the line extend past or fall short of the solid's outer faces? Does the solid have a centerline you can select?
John Mayo
Message 4 of 10
in reply to: jmayo-EE
The line is from the centre if the pipe (at the end of the solid) to the centre of the other end of the pipe (end of solid) - red lines,
I have attached a screen shot, may this explains it better.
Thanks for the help, much appreciated.
Rob
Message 5 of 10
Attached is the autocad file, might help
Rob
Message 6 of 10
jmayo-EE
Did you create the connection point correctly?
This is the tutorial I have used with success.
https://www.youtube.com/watch?v=DfIh2rK7vA0
John Mayo
Message 7 of 10
jmayo-EE
I think your coordinate system may be messing this up.
Go into world coordinates using the plan command. Then issue the orbit command to get a 3d view in world coords. Then define the part.
John Mayo
Message 8 of 10
jmayo-EE
Check that tutorial. I do not believe two connection points are allowed.
John Mayo
Message 9 of 10
Thanks for the help, as it turns out there was nothing wrong with the content. The tutorial on youtube also had the error.
I could not insert the content into the Content Catalog Editor on my computer, it just crashed. I assumed I had done something wrong in making the content. The Content Catalog Editor on my computer has a problem.
I did manage to insert all the content I have made on another computer and every thing is working as it should.
Thanks again, all the help is appreciated.
Rob
Message 10 of 10
jmayo-EE
Glad you got it worked out. I have not used these tools in over a year but I knew I was able to create the parts I needed with that tutorial. I forgot he had the same issue. 😮
John Mayo
Rail Community
