I’m using civil 3D 2015, and when I try to create pressure pipe content I run into problems.
Let me explain how I have been going about it.
Command: PUBLISHPARTCONTENT
Select a solid for publishing
Select a centerline ENTITY that represents the previously selected solid.
Specify the Measuring Unit [Inches/Millimeters] <Inches>: M
Specify the Part Type [Cap/COupling/CRoss/Elbow/Hydrant/Plug/PUmp/Reducer/Tee/Valve/Wye] <Elbow>: V
_VSCURRENT _G _zoom e _pngout C:\Users\Rob\AppData\Local\Temp\cb446570-83ad-4573-8fb3-c437ebe330aa\tempfile.png _ALL
Error during Publish: eWasErased
Please, where am I going wrong or what am I doing wrong?
All your help is much appreciated
Rob
I'm not sure but I think the issue has to do with this,
Does the line extend past or fall shor of the solid's outer faces? Does the solid have a centerline you can select?
John Mayo
Does the line extend past or fall short of the solid's outer faces? Does the solid have a centerline you can select?
John Mayo
The line is from the centre if the pipe (at the end of the solid) to the centre of the other end of the pipe (end of solid) - red lines,
I have attached a screen shot, may this explains it better.
Thanks for the help, much appreciated.
Rob
Did you create the connection point correctly?
This is the tutorial I have used with success.
https://www.youtube.com/watch?v=DfIh2rK7vA0
John Mayo
I think your coordinate system may be messing this up.
Go into world coordinates using the plan command. Then issue the orbit command to get a 3d view in world coords. Then define the part.
John Mayo
Thanks for the help, as it turns out there was nothing wrong with the content. The tutorial on youtube also had the error.
I could not insert the content into the Content Catalog Editor on my computer, it just crashed. I assumed I had done something wrong in making the content. The Content Catalog Editor on my computer has a problem.
I did manage to insert all the content I have made on another computer and every thing is working as it should.
Thanks again, all the help is appreciated.
Rob
Glad you got it worked out. I have not used these tools in over a year but I knew I was able to create the parts I needed with that tutorial. I forgot he had the same issue. 😮
John Mayo
