JamaL9722060
Message 1 of 11 (697 Views)
Creating points at the stations of an alignment,
697 Views, 10 Replies
10-18-2012 01:43 PM
I wanted to get the (x,y,z) of the stations of an alignment, but sounds not to work.
In the screenshots below, I got the message “The specified station is not valid for this object” and couldn’t proceed! How this issue might be solved?
Thank you
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
Joe-Bouza
Message 2 of 11 (672 Views)
Re: Creating points at the stations of an alignment,
10-18-2012 08:14 PM in reply to: JamaL9722060
Jamal,
Home>> Points >> create point along alignment. key in a value that is within the station range
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
JamaL9722060
Message 3 of 11 (662 Views)
10-19-2012 12:52 AM in reply to: Joe-Bouza
Thank you Joe-Bouza for the help.
I couldn’t find the option “create point along alignment”! the screenshot is attached.
Firefox 20.0,
Kaspersky 2013.
Valued Contributor
bpoleuca
Message 4 of 11 (658 Views)
10-19-2012 01:41 AM in reply to: JamaL9722060
The function DIVIDE you can use when you want a number of segments.
The function MEASURE you can use when you want to have the lenght you need and at the last portion you will have a diferent lenght. So I think you can use MEASURE.
PS.
1. How can I give the profile in reference to take the Z value?
2. If you want to have X,Y,Z you must use points from coridor?
JamaL9722060
Message 5 of 11 (655 Views)
10-19-2012 01:57 AM in reply to: bpoleuca
Many thanks
To answer your two questions, please, have a look on the screenshots below.
My issue is how to create points (in a group say g3) at the stations of the alignment! That’s all!
Firefox 20.0,
Kaspersky 2013.
Valued Contributor
Postmaster_G
Message 6 of 11 (373 Views)
04-07-2014 12:47 PM in reply to: JamaL9722060
I know this is an old thread, but did you ever solve this problem?
JamaL9722060
Message 7 of 11 (348 Views)
04-08-2014 11:08 AM in reply to: Postmaster_G
Sorry Postmaster. I didn’t any answer for this issue.
Firefox 20.0,
Kaspersky 2013.
Member
ntimba256
Message 8 of 11 (125 Views)
10-02-2014 08:07 AM in reply to: JamaL9722060
Letme get you right, you want the centreline x,y,z at 1+000, 2+000 sort of interval?
if thats so i have an answer for you
doni49
Message 9 of 11 (113 Views)
10-02-2014 12:39 PM in reply to: Postmaster_G
You're looking to create points every x number of feet along the alignment?  Use "Measure Alignment" as shown in this screenshot.  Set Prompt for Elevation and Prompt For Description to NONE.  Then when you run this command, it'll prompt you to select the Aignment, enter the start and end stations, the offset (which I'm guessing you'll want to be 0.00) and the interval.  Then it'll place a cogo point ever INTERVAL distance along the specified alignment between the start and and end stations as specified.
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Customization
Other Helpful links:
My File is too large to post or I can't post it due to privacy issues!
doni49
Message 10 of 11 (110 Views)
10-02-2014 12:42 PM in reply to: JamaL9722060
Jamal,
The answer was provided for you way back when...
http://forums.autodesk.com/t5/autocad-civil-3d-general/creating-points-at-the-stations-of-an-alignme...
Don Ireland
Forum links:
Civil 3D General
