Civil 3D Forum
Creating points at a specific number
15 REPLIES 15
Message 1 of 16
t2lv
4703 Views, 15 Replies
I am trying to set several hundred points along polyline verticies with the point number starting at 5000. There are no other points in my drawing, yet everytime I start the process, it begins at 1. I have set 5000 at my Next Point Number under Point Identity in the Create Points toolbar. I have also verified that the 'Save Command Settings" is set to yes under the 'Commands-Create Points'. We cannot get this to behave as desired.
Can anyone tell me what I'm missing? This is a 2D polyline with no elevations.
Civil3D 2013 64 bit.
15 REPLIES 15
Message 2 of 16
ToddRogers-WPM
in reply to: t2lv
On the Settings tab, expand point, expand Commands, right click on CreatePoints, Edit Feature Settings...
Todd Rogers
Message 3 of 16
t2lv
in reply to: ToddRogers-WPM
My settings are identical except for the point number, but I cannot get the point numbering to change. I have no problem in 2012, but this is my first go around in 2013. My partner gets the same results on his updated workstation. I have attached a clipping.
Message 4 of 16
ToddRogers-WPM
in reply to: t2lv
In your create points toolbar, expand the chevron to the right and make sure that the point number states 5000.
Todd Rogers
Message 5 of 16
Jeff_M
None of the Point Creation commands, that I've tested, in 2013 honor the next point number property. Another bug discovered.
Message 6 of 16
ToddRogers-WPM
in reply to: Jeff_M
it works fine for me.  You must make sure that the Next point number is set in the Feature Settings and in the Create Points toolbar.  If it's not working, can you post the drawing so I can take a look at it?
Todd Rogers
Message 7 of 16
Alfred.NESWADBA
in reply to: Jeff_M
just tried it with "manual point" and Civil3D 2013 German .... works for me (see video, maybe there are different workflows, command-calls, clicks, ... that makes the difference).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 8 of 16
Jeff_M
in reply to: Alfred.NESWADBA
OK, Manual does work. The Automatic, On Line/Curve, and Polyline Vertices - Automatic definitely do not.
Message 9 of 16
ToddRogers-WPM
in reply to: Jeff_M
Good to know.
Todd Rogers
Message 10 of 16
t2lv
I can control the point numbering fine for a single manual point setting, but when I pick a polyline to set points automatically along the vertices, it returns back to ignoring my settings.
Message 11 of 16
ToddRogers-WPM
in reply to: t2lv
Same thing here happens to me.  Manual works fine, along polyline, NOPE.
Todd Rogers
Message 12 of 16
Hello all,
This issue is already reported to the development and they are actively working on it.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 13 of 16
t2lv
in reply to: AlmasSuljevic
We have found that the numbering also does not work with alignments - Measure alignments. It will work with individual stations and offsets though. Just cannot handle automated multiple points.
Message 14 of 16
t2lv
in reply to: t2lv
Happy days! SP1 installed today seems to have fixed the problem. Starting point numbers are held and automatic placement will keep the numbering consistent. Thanks!
Message 15 of 16
mathewkol
in reply to: t2lv
This is indicated to have been fixed in SP 1 for 2013.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 16 of 16
Thanks for the solution. Mary Thomas Citrus county, FL
Rail Community
