Hello all,
I have a number of 3D polylines that where exported from SDF previously created. They have numerous vertices, each one with a given elevation.
Could someone help me by tellling me how can i create/highlight the higher and/or lower point in each 3D polyline??
A different solution would be automatically breaking these polylines in slope changing points (i.e. high or low points).
I understand that i can create points according to slope or elevation, but it has to be done manually, each poly at a time, and by tipping numeric values that i am sure that a powerfull software (as Civil 3D is) is able to calculate using the drawing information.
Thank you very much in advance by your help.
Rui
Solved by Jeff_M. Go to Solution.
You could create points on the polyline then sort the point list by elevation.
Allen Jessup
Engineering Specialist / CAD Manager
