Civil 3D Forum
Creating Help Files for SubAssembly Composser
3 REPLIES 3
KPerison
433 Views, 3 Replies
I want to start creating help files for the SA's I'm producing.  I've downloaded the Microsoft Help Workshop program and began watching a few videos and tutorials on how to create the .CHM files from scratch.  However, "from scratch" sounds like too much work!! 😞
Anyhow, is there some way to use one of the existing SubAssembly help files as a template for my new SA's?  Or is there a sample/template Project file (.hhp) out there to use as a starting point.  I would like to get the same format, fonts, headings, tables, etc  as the existing SA help files.
Thanks.
3 REPLIES 3
mathewkol
in reply to: KPerison
Help these days is generally HTML. Not too many CHM's out there anymore. I create mine in Word and save to HTML.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
There are some programs out there that will "decompile" a chm back to an HTML help project, not sure if there are any free ones though. Adobe Robohelp & Madcap Flair are paid programs I've used in the past for this purpose.
We use Word to make .mht files (basically a zipped up html file with all the resources such as images compressed into a single file), we then use "Precision Helper" to compile the chm. Precision Helper is a freeware program that you can make a donation if you like it.
We ended up making our own template to use with a similar layout but using a different color scheme so that you can easily tell when you've hit a help topic for a Autodesk SA or one of our custom SAs.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
KPerison
in reply to: mathewkol
As a test, I copy and pasted the Help page from the stock "RetainWall_Vertical" SA into Word. Then saved it as HTML. I then selected that new HTML inside SAC as my help file. When I imported the SA into C3D and checked the help, none of the images were brought along.
Rail Community
