I want to start creating help files for the SA's I'm producing. I've downloaded the Microsoft Help Workshop program and began watching a few videos and tutorials on how to create the .CHM files from scratch. However, "from scratch" sounds like too much work!! 😞
Anyhow, is there some way to use one of the existing SubAssembly help files as a template for my new SA's? Or is there a sample/template Project file (.hhp) out there to use as a starting point. I would like to get the same format, fonts, headings, tables, etc as the existing SA help files.
Thanks.
Solved by michael.robertson. Go to Solution.
There are some programs out there that will "decompile" a chm back to an HTML help project, not sure if there are any free ones though. Adobe Robohelp & Madcap Flair are paid programs I've used in the past for this purpose.
We use Word to make .mht files (basically a zipped up html file with all the resources such as images compressed into a single file), we then use "Precision Helper" to compile the chm. Precision Helper is a freeware program that you can make a donation if you like it.
We ended up making our own template to use with a similar layout but using a different color scheme so that you can easily tell when you've hit a help topic for a Autodesk SA or one of our custom SAs.
