I am trying to set up my traverse points by building control points to start. When I get to the description on how to build control points, it says:
In Toolspace, on the Survey tab, right-click the Control Points collection. Click New to open the New Control Point dialog box.
Where is the "New Control Point" dialog box? I cannot find it.
Any help would be much appreciated.
Solved by AllenJessup. Go to Solution.
OK. First you have to have created a Survey Database them you have to create a network. So rt-clk on Survey Databases and select New, expand the new database, rt-click on Networks and select New, expand the new network and rt-clk on Control Points and select New. Now you should see the dialog box.
Allen
Allen Jessup
CAD Manager - Designer
Glad it worked. That was the first time I'd tried it.
If this answered your question you might want to mark it as the Accepted Solution to lead others to the answer. And to help me make "Guru".
Allen
Allen Jessup
Now I would like to come back to this database and add control points to the existing data. When I go in to edit the database of points, it will not let me add new points.
Where do I go to add more control points?
Rob
